System nearly done -- new pics
Originally Posted by chrissa,Jan 29 2004, 07:01 PM
William, thanks for the good news! Lately, I've had a ton of trouble with my IPS, so I'm not surprised they are now bouncing e-mails too.
Thanks for the info on the PG amps. I've checked out their website and read about how they handle a 2 ohm bridged load. They do use some current limiting circuits. If the current draw is too large for too long at a 2 ohm load, the amp will turn off. They say the chances are pretty slim that the conditions to turn the amp off would happen, but I'd like to hear from some people who are actually using the same parts as I'm going to. I've been toying with the idea of getting a Titanium 500.4.
Chris.
Chris.
Originally Posted by Icemn2003,Jul 27 2004, 07:51 PM
Hey sorry to drag up the past this much, but I find myself in a similar situation. I have the same amp with an Alphasonik PSW608, which is also a 2 ohm DVC. I can't find this info on the PG website, but I'm a little worried about damaging something here, am I cool? Thanks
i do not recall the Tantrum amps being 1 ohm stable... so, you'd have to run the Alphasonik in a DVC series config for 4 ohms total load.
i'm 99.9% sure the Tantrum is 2 ohm stable when mono bridged. you should be good to go. wire the sub for parallel and a 2 ohm load.
and if XMatt's is using it for an e8a.44, you should be fine. i know i helped him a lot w/ his stereo, and i wouldn't have steered him wrong on that.
Thanks for the heads up, I was worried, but I feel better about the whole situation now. PG techs told me also that it will be stable at 2 ohm, but run hot, so I may need to install some fans. Thanks for your reply though PJK3!
