T6668
Old May 9, 2010 | 07:27 PM
weeqoo's Avatar
Default T6668
Edited by seekic.com,the leading IC purchasers' best choice of platform for one-stop valued service!
Description:
The T6668 is a single chip CMOS LSI for voice recording and reproducing using the ADM(adaptive delta modulation) system. When a dynamic RAM is used as a voice data memory and an audio circuit including a microphone, speaker, amplifier, ete.is externally connected, a voice recording/ reproducing system can be composed.
The T6668 has the following features1)a single chip LSI for voice recording / reproducing.;(2)D-RAM (Dynamic RAM) used as a voice data memory with the capacity up to 4pcs. of 64Kbit or 4pcs. of 256Kbit;(3)built-in counter to refresh D-RAMS;(4)easy connection with CPU. control by 9 kinds of commands;(5)capable of recording/ reproducing of max. 16 phrases;(6)selectable 4 kinds of bit rates (32k, 16k, 11k, 8kbps);(7)recording tone of each phrase is variable (MAX.128 sec. at 256KD-RAMX 4, bit rate 8kbps);(8)built in microphone amplifier for sound recording and band path filter for sound reproducing;(9)built in to bit D-A converter, voltage follower output;(10)built in oscillation circuit for ceramic resonator;(11)single 5V power supply:1mw power consumption by CMOS structure;(12)60 pin mini flat package.
The absolute maximum ratings of the T6668 are1)input voltage:-0.3 to Vdd+0.3;(2)output voltage:-0.3 to Vdd+0.3V;(3)supply voltage:-0.3 to +6.0V;(4)storage temperature range:-55 to +125°C.
siadam
Apr 28, 2011 03:35 PM
Imarriedmys2k
Oct 23, 2010 05:28 PM
Rick
Dec 24, 2002 10:58 PM
JoeD
Jul 28, 2002 05:19 PM
