Is there a way to plug an iPod into the headunit?
Old Oct 16, 2003 | 07:57 PM
JRock's Avatar
Default Is there a way to plug an iPod into the headunit?
Curious if there's any sort of mini-input jack on a stock headunit. I've always dreamed of being able to connect an mp3 player like an iPod to a headunit without having to resort to the low-quality cassette adapter gimmick.
I'm sure there are aftermarket headunits out there with inputs which could somehow accept a quality connection from an outside source but I'm guessing that's not possible (within reason for a non-engineer) on a stock Honda unit, right?
Old Oct 17, 2003 | 02:43 AM
3ngin33r1's Avatar
I don't think the stock headunit has the input ability to do this, unless you somehow tap the changer input leads but then you may have to deal with a mismatch. For a non-engineer it probably won't be a simple task.
Old Oct 17, 2003 | 05:34 AM
ronblanford's Avatar
Many people are using the Hon-Aux converter to plug into the CD changer input of the stock head unit. There was a long thread about Hon-Aux.
Old Oct 17, 2003 | 06:19 AM
JRock's Avatar
oh neat that might be the right solution! thanks.
i wonder if the 04 hu is the same as the 03, or close enough that it still holds true and will work with that part.
btw, is there a 6-disc changer available for the s2000 or just single in the dash and an optional 6disc cartridge in the trunk?
Old Oct 17, 2003 | 11:43 AM
3ngin33r1's Avatar
single in dash and optional trunk.
Old Oct 19, 2003 | 02:02 PM
Luft46's Avatar
Using the PIE Aux adapter, I now have a MiniDisc walkman, cassette tape walkman and satellite radio that I use through the stock head unit. If you need any help, PM me...
08s2000CRbackinblack
Jul 14, 2009 06:50 PM
Lane03
Jan 23, 2009 12:03 PM
Paul_c
Jan 11, 2007 04:17 AM
smurf2k
Jul 20, 2006 05:47 PM
skafia
Apr 2, 2004 08:09 PM
