Is there a wire pass-through on passenger side?
I'm wiring up my amp and have hit a snag. Since the battery and amp (in the trunk) are both on the passenger side, I was hoping to run power straight down that side of the car but can't find a pass-through on that side.
if you remove the battery, you'll see a grommet that passes through the
firewall - remove the electrical tape that wraps it and if you lube up your wire, you can push it through without cutting the grommet. The wire will drop down by the passenger's feet, then you can route it through the sill straight back into the trunk. |
Thankyou!!! :)
if there is more than one grommet/harness there, it's the lower one.
BTW, my experience is with a 2001, but I don't believe anything has changed. |
That's the one. I was able to get 4ga through there without TOO much trouble.
Remember to run the power wire seperate from the RCA. I ran the RCAs down the center, and the power under the passenger sill. Again, I ran 4ga for the power, and there was plenty of room. |
is there a place to fit either (1) 0 gauge wire or (2) 4 ga+ (1) 8 gauge through?
or is the best way just to drill a hole somewhere? thanks |
