Is there a wire pass-through on passenger side?
Old Apr 25, 2008 | 05:53 PM
plutonium239's Avatar
Default Is there a wire pass-through on passenger side?
I'm wiring up my amp and have hit a snag. Since the battery and amp (in the trunk) are both on the passenger side, I was hoping to run power straight down that side of the car but can't find a pass-through on that side.
Old Apr 25, 2008 | 07:22 PM
oth's Avatar
oth
if you remove the battery, you'll see a grommet that passes through the
firewall - remove the electrical tape that wraps it and if you lube up your
wire, you can push it through without cutting the grommet. The wire will
drop down by the passenger's feet, then you can route it through the sill
straight back into the trunk.
Old Apr 25, 2008 | 07:42 PM
Thankyou!!!
Old Apr 25, 2008 | 08:46 PM
oth's Avatar
oth
if there is more than one grommet/harness there, it's the lower one.
BTW, my experience is with a 2001, but I don't believe anything has
changed.
Old Apr 28, 2008 | 11:12 AM
ruexp67's Avatar
That's the one. I was able to get 4ga through there without TOO much trouble.
Remember to run the power wire seperate from the RCA. I ran the RCAs down the center, and the power under the passenger sill. Again, I ran 4ga for the power, and there was plenty of room.
Old Apr 29, 2008 | 08:17 PM
DBXFX's Avatar
is there a place to fit either (1) 0 gauge wire or (2) 4 ga+ (1) 8 gauge through?
or is the best way just to drill a hole somewhere?
thanks
Bacchus
Mar 19, 2016 04:35 PM
GunNam
Aug 5, 2010 12:49 PM
tbonesteak
Dec 25, 2006 10:38 PM
THAGR81
Aug 7, 2002 10:49 AM
Kibro
Sep 16, 2001 11:47 AM
