Too much power going to a speaker?
Old May 6, 2009 | 04:42 AM
  #21
adamjgriffin's Avatar
Originally Posted by adamjgriffin,May 4 2009, 04:27 PM
Noob too, but always thought that too little power was worse than too much, as its the clipping of the sound that is more likely to damage the speaker???
Alternately, if you have a 75watt amp that you try to drive to 100watts,
the output will be clipped (distorted) and the waveform that the speaker
is trying to reproduce is not a shape it's designed for, so even though
you have not exceeded that speaker's maximum, you could still damage
the speaker
This is what i meant by too little power, but written so much more eliquently and concisely than myslef Learnt alot from this thread
Old May 6, 2009 | 07:56 AM
  #22
DFWs2k's Avatar
how can you drive a 75 watt amplifier 100 watts? the only way I can think of is messing with the resistance?
Old May 6, 2009 | 09:46 AM
  #23
Neutered Sputniks's Avatar
^^ Both you guys should check out the link I posted.
It explains how clipping actually increases the power the amplifier is putting out (over the max ratings even ) - which is why clipping is bad, mkay.
Old May 6, 2009 | 09:57 AM
  #24
DFWs2k's Avatar
lol, ok, i'll read
Old May 6, 2009 | 02:20 PM
  #25
DFWs2k's Avatar
can you point out something more in-depth?
Old May 6, 2009 | 02:25 PM
  #26
DFWs2k's Avatar
nm...found this...http://en.wikipedia.org/wiki/Clipping_(audio)
Old May 6, 2009 | 02:29 PM
  #27
DFWs2k's Avatar
Under "sources of clipping", it only talks about analog audio equipment. is that what is primarily used in car audio? or is there any difference with digital audio equipment, in relation to sources/general causes of clipping?
Old May 6, 2009 | 02:58 PM
  #28
Your amps work in analog and output from the HU is analog...
Speakers are analog - they don't really do digital.
Think of digital as being a purely off/on switch. So your speakers would be at max excursion or at min excursion if they were digital.
Old May 7, 2009 | 06:27 AM
  #29
DFWs2k's Avatar
oh, makes sense, thanks
m1sterlaw
Oct 13, 2011 09:18 AM
Ubetit
Nov 9, 2010 12:50 PM
sandelkw
Mar 4, 2006 06:58 AM
Darien1629
Apr 21, 2005 05:53 AM
kw2000
Jan 15, 2005 07:03 PM
