Trunk doesn't pop with keyless entry
Old Mar 9, 2013 | 07:38 PM
dustin02rsx's Avatar
Default Trunk doesn't pop with keyless entry
Hopefully I'm not re posting, but my keyless entry works to lock and unlock my doors, but the trunk button doesn't do anything. The button inside the glove box opens the trunk, but the key fob doesn't. Anybody know how to fix this?
Old Mar 9, 2013 | 08:55 PM
d-bo's Avatar
mine doesn't work either. interested in knowing too
Old Mar 9, 2013 | 09:23 PM
JulieU's Avatar
Administrator
Some things to check...
Originally Posted by wirejock
Just in case someone needs help with this problem, mine stopped working recently. Here's what I checked and what I fixed.
1. Fuse # 26 under the drivers side. It's the top one on the right side. 15 A Checked fine.
2. Fuse in the main panel under the hood. #34 I think. Checked fine.
3. Applied power to #1, ground #2 of the solenoid connector in the trunk. Looking at the connector # 1 is left, #2 in the middle. Positive is Black/yellow stripe. just a touch of power to the positive terminal should activate the solenoid. Checked fine.
4. Checked for power and ground at the connector coming from the wire loom. No power or ground when button is pressed.
5. Opened the wire loom where it snakes past the driver's side trunk hinge. It feeds into a larger loom near the rear deck. Both hot and ground pull out freely. Both are broken. Since my car is stock, it must be a design flaw. Opening and closing the trunk eventually caused the wires to break where it is wire wrapped really tight to keep it from moving.
The fix was as follows.
Cut the wire wrap under the rear deck. One black wire wrap holds it in place. Completely open the plastic duct over the four wires feeding from the corner panel to the trunk hinge enough to work on the splice. Bare all four ends 1/2 inch each. Cut two pieces of equivalent size wire 3" long. bare all four ends of the short pieces. Cut two pieces of shrink wrap long enough to cover both splice points with one piece. Slide one on each of the longer existing wires. The ones from the trunk were longer. Twist one pair at a time, solder then move to the next pair till all four splices are done. Test the trunk switch. If it works, and it should, slide the heat shrink up and heat it. Tuck the wires back into the loom. All done and it should look just like it did before.
Honda, calm down with the wire wrap. Way too tight.
Old Mar 10, 2013 | 07:27 AM
lopez14's Avatar
are you guys holding the trunk button of the fob? You have to actually hold that one not just push it like the lock/unlock
Old Mar 10, 2013 | 10:40 AM
Problem solved.... I feel stupid lol
doheboy6
Oct 27, 2019 12:38 PM
Snakecharmer
Apr 21, 2016 08:25 AM
Arrow Head
Jun 1, 2015 06:48 AM
#172CR
Aug 19, 2009 01:20 PM
SandyS2K
Apr 22, 2004 05:03 AM
