Tweeter question and another general question
Old Feb 11, 2004 | 07:27 AM
tenblade2001's Avatar
Default Tweeter question and another general question
Do you need the 02 and up radio to use the stock door tweeters? There are some 02 door pannels available and I was thinking about gettin them, but I have a 01. Second thing, I was thinking of trying to split the wires going to the 12V charger. I am looking to place another charger in the "glove box" and have a phone mount there. By splitting the wire, essentially having 2 outlets fromt the same wire, would I cutting my voltage by 1/2?
thanks
Old Feb 11, 2004 | 07:52 AM
darkknight1999's Avatar
So you want to add a second changer?
Old Feb 11, 2004 | 07:58 AM
yup
Old Feb 11, 2004 | 10:06 AM
xviper's Avatar
Steve, looking at the wiring diagram of the stock tweeter setup, it appears that those tweeters are simply wired "in parallel" with the main door speakers, so it shouldn't be an issue. I was going to add tweeters to my setup but shelved it when I discovered how much Honda wanted for the door panels. It's good that you found some cheap.
As for splitting the power of your accessory socket, NO, you will not cut your voltage by 1/2. It'll still be 12V. However, if you plug something into both at the same time, you might exceed the amperage and blow the fuse. I do not believe a cell phone car charger is a high amperage unit, so you should also be fine here.
(edited to read "in parallel")
Old Feb 11, 2004 | 10:10 AM
heffergm's Avatar
Hmmm... I just bought an 02 radio for my 00. The 02 radio has a plug in for a second wiring harness that the 00 radio didn't have (smaller than the main harness).
Any idea what this is for?
Woodson's Avatar
Tenblade, just buy some bargain component speakers. For less than a hundred bucks you will have far better sound than the crap stock speakers.
And yes you can use the 01 radio.
Old Feb 11, 2004 | 10:15 AM
xviper's Avatar
My '00 has an empty plug-in which I assumed was for the factory optional CD changer. Are saying that yours has 2 empty plug-ins?
Old Feb 11, 2004 | 10:17 AM
heffergm's Avatar
Hmmm... no, there are two plugins on the back of the 02 radio. I could have sworn there was only one on the 00 radio. Maybe my memory is going....
Old Feb 12, 2004 | 12:34 AM
PortugueseS2K's Avatar
Interesting cuz im thinking of doing the same. I was looking at 02-04 panels also. Just curious where are you getting the panels from Good price Seems we dont have a flush panle to mount tweeters on the 00-01
Old Feb 12, 2004 | 04:41 AM
Why not buy aftermarket speakers and cut them into your door panels? Its very easy to do...
