The ULTIMATE way to slide and piggyback wires
Ok, just some tips if anyone is trying this in the future. I'm putting in my own stereo and have never done anything like it before but I really like learning about the way things go together. Anyway, I saw that people had suggested using soapy water to snake wires through the conduit in the doors and from the engine compartment. Well, let me tell you...I didn't want to get soapy and since KY is petroleum based lubricant...LOL...I used some silicone based lubricant from the local "store" and it worked GREAT!!! Eros Bodyglide BABY!!! LOL...anywayz dats my 2 cents.
KY is waterbased its not good to use petro based well in THERE... but I digress...
Here's my take on the snake... Get 2 ft of Romex 14-2 house electrical wire or the like. Pull out the ground wire. Discard the rest. Strip off about 3/4-1" of wire on both of your new door speaker wires. Tie them together. Solder them to the end of the ground wire. do it nicely. use heat shrink tubing to cover them (making it nice and smooth. Fish it through. Use a lube if needed. |
I wanted to share the same info as well! I have starting upgrading my stereo and last weekend I ran a 4 gauge power cable thru that gromet behind the battery. At first it did not look like I'd be able to do it but then i said "what the hell.." and put some body lotion in the gromet and on the wire and WOW! It just slid right thru! I lubed the rest of the cable as well cause it made it really easy :-) BTW, this was a really thick wire, even for a 4 gauge.
[QUOTE]Originally posted by Phormula_01 [B]Ok, just some tips if anyone is trying this in the future. |
The best fish tape I have found for cars (not my idea, found it here) is one of those huge zip ties that the HVAC guys use to tie off stuff. They are about 3 feet long. Cut off the big end, round off the small end with snippers, and fish away! They are flat yet hold their form, and plastic so no damage is likely. Lube if necessary.:)
Originally posted by wFo The best fish tape I have found for cars (not my idea, found it here) is one of those huge zip ties that the HVAC guys use to tie off stuff. They are about 3 feet long. Cut off the big end, round off the small end with snippers, and fish away! They are flat yet hold their form, and plastic so no damage is likely. Lube if necessary.:) BTW: Its call a Mr. T :) (Mr. Tie wrap). The best line I heard from my installer was WHERE IS ORANGE T?!?! Obviously now that I look back on it but at the time I was like WTF is Orange T? Its an orange tie wrap! |
Hey Pinky! Was that you that originally posted that? It sure works good.
I visit a lot of residential construction sites for my job. I find these zip ties all of the time. The guys who do the heating and air conditioning use them to tie off the smaller ducts and whatnot. Often times the end they cut off and leave for scrap is perfect for our use. I have never looked, but I bet that home depot would have these.... |
