Volume Rocker Knob Replacement?
Old Jun 24, 2006 | 04:04 PM
balakris's Avatar
Default Volume Rocker Knob Replacement?
The dumb valet guy damaged my rocker knob for the radio volume. It now doesn't have a positive "click" feel when I increase the volume. It works, but I have a feeling that it will go out soon because I have to press fairly hard to increase the volume.
Is there a procedure to replace this knob, and perhaps the springs behind it painlessly? Do I have to take apart the dash for this?
Any help is appreciated!
Old Jun 24, 2006 | 08:08 PM
xviper's Avatar
The dash has to be pulled out to access screws that hold the radio control panel in place. The panel can be dismantled from behind.
Old Feb 15, 2009 | 12:30 PM
student_driver's Avatar
my rocker knob does not lower the volume, it's limp and only the top half to raise the volume works. What exactly will need to be replaced after i take the dash off?
Old Jul 13, 2009 | 11:33 AM
anybody?
Old Jul 13, 2009 | 04:39 PM
oth's Avatar
oth
here's an exploded view of the dash switch - looks like the radio switches are
part of a single unit "SWITCH ASSY., RADIO REMOTE"
(from http://www.hondaautomotiveparts.com)
Old Jul 13, 2009 | 06:58 PM
so when the rocker switch is no longer able to turn the volume down it means paying over 200 dollars to fix it? That's F-ed up
Old Jul 13, 2009 | 07:29 PM
Agate's Avatar
Or you could find a car in a junkyard, or someone in the marketplace who's parting out theirs.
Old Jul 14, 2009 | 05:11 AM
2big4aS2000's Avatar
here is how i remove them,
use pick tool to pop out plugs inside dash bezel area, remove screws
loosen front 2 steering column bolst, remove rear 2 steering column bolts - this will allow the steering wheel to fall down and rest on seat, carefully pull guage cluster out around edges, you can get it out slightly then pull the audio control side out, disconnect start button wires and pop it out, there are 2-3 screws that hold it in take them out, next twist it and it comes out the front. reverse for assembly (less than 5 min)
Old Jul 14, 2009 | 05:16 AM
takeshi's Avatar
I doubt you'll find that you can buy every single sub-component cheaply from the dealer for any car out there. As stated above, there are ways of getting parts for less.
Old Jul 15, 2009 | 11:28 AM
Originally Posted by 2big4aS2000,Jul 14 2009, 05:11 AM
... next twist it and it comes out the front. reverse for assembly (less than 5 min)
and once you get them off, is there a spring that sits behind the knob?
