What am I doing Wrong?
Old Jul 30, 2007 | 06:01 PM
han racer's Avatar
Default What am I doing Wrong?
Isn't this how you install components? I've tried every wire combination...
Old Jul 30, 2007 | 06:10 PM
PTHermes's Avatar
There are 6 terminals. Two should be labeled IN +/- This connects to your power source. From you photo I am assuming you ran some speaker wire to the door. The other terminals should be WF +/- goes to the bigger speaker in your hand. TW +/- goes to the tweeter shown on the box.
Best of luck to you.
Old Jul 30, 2007 | 06:15 PM
han racer's Avatar
Got the TW and the WF, but where should the wires be for the IN?
Old Jul 30, 2007 | 06:16 PM
DDuds2k's Avatar
you have 2 sets of speaker wire going into one terminal for some reason. Bascially think of the crossover as a spliter:
Speaker wire run from amp(or)headunit to door goes into the IN- and IN+
The other set of terminals are for your woofer and tweeter. W+ and W- and T+ and T-, obviously w for woofer, t for tweeter. Run positive to + and neg. to minus for each, and then mount.
Answer your question?
Old Jul 30, 2007 | 06:34 PM
han racer's Avatar
Ok yeah, thanks guys, however I've just tried doing it the new way and still nothing, anything wrong with this picture (Ive tried mixing&matching the wires)
Old Jul 30, 2007 | 06:36 PM
han racer's Avatar
BTW I have a crappy receiver ( a kenwood KDC-135 ) that the dealer installed, could that be part of the problem, I don't have to re-do anything to make the speakers compatible with it do I???
Old Jul 30, 2007 | 06:55 PM
JackS's Avatar
The speaker wires (2) that you unpluged from the stock woofers must be extended by using an adopter if you have one or by cutting the stock adopter off and splicing about 12-18 inches of wire and then inserting this longer wire into the +/- (input) on the crossover box.
Using about the same length of wire, connect both wires to the OUTPUT on your crossover box and then connect these two wires to your new woofers.
Old Jul 30, 2007 | 07:06 PM
han racer's Avatar
Okay update (like you guys care ) I got the passenger side speaker to work but the driver side is nada...What could be the problemo???
Old Jul 30, 2007 | 08:13 PM
JackS's Avatar
Assuming your connections are correct, it's got to be an incomplete connection of one of your wires. Assure all connections are solid.
Old Jul 30, 2007 | 08:27 PM
WLAURENT's Avatar
Could be a dead cross-over also - try swapping the xover from the working side to the non-working side.
Dealer probably did a hack job on the install of the HU - may want to recheck all wiring back there also.
