What do I need?
Old Apr 6, 2013 | 11:05 AM
hondavet's Avatar
Default What do I need?
So I bought my car with the current setup and now I want to add a 10 inch sub. Currently I have a set of kenwood dualmag components powered by an alpine mrv-t420, which sound amazing for what I can expect from them. This is running off of the stock head unit btw and I plan to keep it stock. So what do I need to do next to power a 10 inch sub? I want to stay away from running 2 amps because I don't feel like rewiring with thicker power wire. But I can't find a decently priced amp that will run two of the components at at least 100watt each and the sub at 300watts bridged? Help me out guys.
EDIT: I found out the sub im planning on using is only 150 watts rms at 4ohms, so basically I an amp that will run 100wx2 to the components and 150 to the sub.
Old Apr 6, 2013 | 11:41 AM
IHoP's Avatar
You're probably going to need a good 4 channel amp to do that. 1 channel per component and the other 2 for the sub. What gauge of wire are you using? Check out this chart. Wire Size Chart Based on your power and cable length you can get a recommended gauge size so you know whether you'll need to rewire or not. Another question people will ask is, what is your budget?
Old Apr 6, 2013 | 11:54 AM
hondavet's Avatar
K ill check a little later. But for my budget, as far as an amp, I'd say a couple hundred. I can be flexibly to myself if I find something that I want though
Old Apr 6, 2013 | 01:08 PM
hondavet's Avatar
The wiring is 8gauge
Old Apr 6, 2013 | 01:46 PM
hondavet's Avatar
I was looking at this one, but it only supplies the components with 75 watts x2
http://www.crutchfield.com/S-QJlXeY5...ml#details-tab
Then I saw this, but is 75 watt or 60 watt enough to run my components?
http://www.amazon.com/Rockford-Fosga...+amplifier+500
Old Apr 6, 2013 | 05:15 PM
hondavet's Avatar
What would YOU guys do?
Old Apr 7, 2013 | 06:49 PM
IHoP's Avatar
What kind of speakers do you have?
Old Apr 9, 2013 | 05:09 AM
hondavet's Avatar
Don't mean to be rude, but did you read my first post?
Old Apr 9, 2013 | 05:11 AM
hondavet's Avatar
Also, I only have one set of rca's running to my current amp. I heard that some amps will pass the signal to the other 2 inputs if only one set of rca's are plugged in. Anyone know if this is true?
Old Apr 9, 2013 | 11:14 AM
IHoP's Avatar
Ya I did but I totally forgot lol. Are these the ones? Dual Mag It says the recommended power range is 2-45 watt rms so you would want an amp that can power each speaker with that rms. So you could get a 4 channel amp and use 1 channel per component and bridge the last 2 for your subwoofer. As for having one rca cable, I believe the amplifiers are able to filter certain frequencies to play in certain speakers. I did the same thing in my last car. Don't quote me though.
