Whats the difference between rated powers?
Old Mar 6, 2007 | 08:46 AM
DDuds2k's Avatar
Default Whats the difference between rated powers?
Here are the specs on a Jl A1400 amp
A1400
Rated Power 12.5 V: 240 W RMS x 1 @ 4 ohm
400 W RMS x 1 @ 2 ohm
Rated Power 14.5 V: 320 W RMS x 1 @ 4 ohm
500 W RMS x 1 @ 2 ohm
anyone know the difference of rated 12.5 and rated 14.5 volts?
Old Mar 6, 2007 | 09:35 AM
00wreckedS's Avatar
12.5 is car not running, just on acc where 14.5 is typically the voltage u get when the enginge is running
Old Mar 6, 2007 | 09:49 AM
oth's Avatar
oth
When I first looked at those specs, they didn't make sense to me:
power should increase AT MOST proportionally to the increase in
voltage, and here voltage is increasing by 16%, but power is
increasing by 33% at 4ohms, and 25% at 2 ohms. I went to the
JL website, and the higher voltage rating is also with 12x the
distortion:
12.5v @ < .08% THD
14.4v @ < 1% THD
I believe the 14.5v rating corresponds to the CES standard,
while the 12.5v rating is JL's more conservative one.
Running at a higher voltage than 12.5, but with a similar low
distortion level should give you a power level somewhere
between the two measures.
Old Mar 6, 2007 | 10:23 AM
DDuds2k's Avatar
thanks a lot. Clears everything up.
Old Mar 6, 2007 | 03:23 PM
NFRs2000NYC's Avatar
JL dumbs down the power at 14.5, so its closer to the 12.2 voltage, and market it as a "regulated power supply." This is why you arent seeing the numbers you are expecting.
Old Mar 6, 2007 | 04:57 PM
oth's Avatar
oth
actually, this particular amp doesn't appear to have a regulated
power supply, and in fact the confusion was that they were quoting
more power at 14.5v than made sense if the 12.5v rating was
accurate.
Old Mar 6, 2007 | 05:05 PM
DDuds2k's Avatar
so...now im confused again. Will this amp do 500x1 at 2 ohms, or will it be closer to 400?
Old Mar 6, 2007 | 05:13 PM
oth's Avatar
oth
this amp will do 500x1 @ 2ohms w/ 1% THD if it's truly getting 14.5v.
if you want the 0.08% THD that it specs at at 12.5v, you'd probably
get 450 watts at 14.5v. Realistically, you probably wouldn't hear
the difference between .08% and 1% THD, especially in a noisy S2000.
Old Mar 6, 2007 | 06:12 PM
DDuds2k's Avatar
sorry...what is THD?
Old Mar 6, 2007 | 08:06 PM
oth's Avatar
oth
THD = total harmonic distortion (lower is better)
