Where can I install 2 amplifiers without using any trunk space?
Old May 11, 2002 | 11:19 PM
Naka's Avatar
Default Where can I install 2 amplifiers without using any trunk space?
I plan to install a JL Audio stealthbox and a pair of Focals 165k (165k2 if they fit). I want to use a 2 channel amp for the fronts (probably a Phoenix Gold Tantrum 300.2) and a mono amp for the stealth box (probably a JL Audio 250/1). Both amps are about the same size (10x9x2.5) My S is my daily driver and I really need the trunk space. Where would you suggest to put these amps, besides the trunk floor? Is there enough space underneath the seats? What about in the firewall on the passenger's side? Any pictures would be helpful to show to my installer. Thanks.
Old May 11, 2002 | 11:24 PM
Shamu's Avatar
I believe What The!? mounted his pair of amps in the spare tire well...you may want to send him a PM for pics...
Old May 12, 2002 | 12:06 AM
Naka's Avatar
Shamu:
I still want to keep my spare though, I commute a lot. I guess I'm probably asking too much.
But I saw there is also a space to the left of the spare. Has anybody installed any amp there? The problem is that I still would need space for the other amp.
Old May 12, 2002 | 12:10 AM
2002S2000's Avatar
Originally posted by Naka
Shamu:
I'd be careful when drilling in that location. That's where your fuel tank is located.
Old May 12, 2002 | 12:34 AM
Shamu's Avatar
Shamu:
Ok, I mounted my PPI amp flush mounted against a custom panel where the old lining for the spare tire runs...kinda hard to explain, but I'll post pics as soon as it's done and hopefully it'll work out for you!
Old May 12, 2002 | 06:45 AM
Elistan's Avatar
Shamu:
Put them on the wall behind the seats. I have a 4ch and a 2ch amp mounted there. I'm short enough (5'9") to not loose any needed seat travel.
Old May 12, 2002 | 07:33 AM
KaCee's Avatar
The JL Stealbox is not quite flush with the trunk floor. I mounted my amp on the JL box cover.
Old May 12, 2002 | 08:22 AM
Naka's Avatar
Thanks guys.
Shamu, I'll be waiting for your pictures
Old May 12, 2002 | 09:50 AM
Shamu's Avatar
[QUOTE]Originally posted by Elistan
[B]
Old May 12, 2002 | 02:37 PM
Naka's Avatar
I read somewhere that it wouldn't be a smart thing to intall the amplifiers behind the seats because if you are caught in the rain, even for few minutes, water would run down straight to the amps. So I think that option is out for me.
