Where is the ground?
I'm upgrading my battery wires with some thicker gauge stuff.
One of the usual things to upgrade is the wore from the engine block to the battery.
However, IT DOESN'T HAVE ONE!
All it has from the battery is a ground that goes to the chassis. I assume somewhere there is a wire from the engine block to the chassis that completes the circuit.
Can someone explain to me where this bolt/ connection on the block is?
Or can i use any bolt on the engine as the primary ground?
No wonder the battery seems so weak! it doesnt even have a real primary connection. It passes through 2 links of the chassis metal to get its current!
Somebody help with this info please!!!
thanks
thanks
im looking for the spot/bolt on the engine block that goes to the chassis as the main ground. the one that sends the (-) signal front the alternator to the rest of the chassis which in turn goes to the battery. i want to upgrade that wire.
thanks,
-Dan
thanks,
-Dan
vietdragontekx
Dec 15, 2010 06:00 AM
