Where is your alarms Brain?
Old Oct 12, 2008 | 07:01 PM
MrChoi's Avatar
Default Where is your alarms Brain?
Just wondering because im about to install my alarm once i get it. Where did you put your alarm's brain or where is a good location for the install.
Thanks.
Old Oct 13, 2008 | 08:41 AM
Penforhire's Avatar
My shop used a custom bracket up under the driver's side dash, solidly bolted to part of the frame.
Old Oct 13, 2008 | 09:14 AM
darkknight1999's Avatar
You wont it way up under the dash. In a place that is a total pain in the neck to get to. Make sure your wires are hidden. They should be taped, tucked and tie-wrapped to look like stock wiring.
Old Oct 15, 2008 | 04:32 AM
jettfiery's Avatar
as long as ur wires aren't obvious ur safe. My brain is pretty well hidden in a panel that requires quite a bit of time to remove. I'm keeping quiet sorry... :-D
Old Oct 15, 2008 | 02:27 PM
Penforhire's Avatar
As if someone is going to steal your S2000, which has an alarm, versus the many that don't...
Old Oct 15, 2008 | 02:32 PM
Stealth_SUX_'s Avatar
If the customer pays more we will hide it in a pretty much imposible spot and change all the wire colors to the exact same.. So even if you see the wires its all the same colors so you wont be able to find the starter kill without a very good amount of time..
Old Oct 15, 2008 | 08:53 PM
MrChoi's Avatar
stealth are you an installer? whats the going rate if you are?
THanks.
Old Oct 15, 2008 | 09:02 PM
are alarms and such include the install if you buy it from us.. which is pretty much how it goes for any shop..
If you bring your own alarm prices are like this
alarm/keyless entry 149
alarm/keyless/remote start 199
but of course it ranges on what shops you go to and where u live.. cali is ussually pretty expensive.
Old Oct 15, 2008 | 10:02 PM
MrChoi's Avatar
Thanks stealth so far you have the best price and im sure you have some experience with s2000's. the last quote i got was in the 350 range. if i cant find anyone closer to where i am i'll contact you. im in the south bay fyi.
Old Oct 15, 2008 | 10:36 PM
350 is kinda high...
but also depends on what ur doing.
if your doing remote start then you will need the immobilizer bypass in which that price is like exact..
