Will a speaker with a 3.08" mounting depth fit
Lets do some quick math:
door skin to window is 54mm (at the top of the speaker opening, 61mm at the bottom).
a 3/4" spacer adds 19mm.
total of 73-80mm mounting depth. However, we can't just use 80mm and be happy because that's only at the very bottom of the window travel. So we go with 73mm to be on the safe side.
3.08in is 78.23mm.
It might fit, but I would probably use a 1" spacer to make sure.
3.08in is 78.23mm.
3.08in is 78.23mm.
3.08in is 78.23mm.
Originally Posted by circuitclub,Nov 2 2009, 03:07 PM
Whats the max spacer you can install without interfering with the door panel? Im thinking of upgrading my speakers soon, but havent done the research till now..
