Wire and Amp question
Old Mar 3, 2006 | 02:11 PM
cshamash's Avatar
Default Wire and Amp question
Firstly thanks a lot for all the previous help. I have just put in my hu,speakers- front and rear, dci, and radar detector. So far so good. My last task is to put in the amp.
I just got my 4 guage wiring kit from KnuKoncept. The 4 guage power wire is supposed to be crimped or soldered onto the terminal. I can't solder so I am hoping to crimp it on. I just tried with horrible results. Is there a tool/technique I should be using. They have included a snap bushing grommet with the ring terminal. How do I use it?
Also I just bought a JL2150 2 channel amp. Will this be enough to push my polk db6500s effectively?
Old Mar 3, 2006 | 02:33 PM
Triig's Avatar
I have never tried to crimp 4 gauge. I have always used solder or set screw type. Here is a link to something similar to what I am using now. Just another easy alternative you can probably find locally at a car stereo shop.
http://www.crutchfield.com/S-R9CG8C421k6/c...g=714&I=211RTS4
Old Mar 3, 2006 | 02:37 PM
jwa4378's Avatar
With wiring that large, you will really need to get some torque. I (or rather my friend) took the little sleeve adapter and set some wire crimps (wiring tool...similar to plyers), and positioned the wire between the tool, and closed it in a screw vice. Took a TON of pressure, but if finally was good and solid.
I agree, though, if you have the soldering stuff available, its usually better and just as fast / easy. It can be done without it, though.
John
Old Mar 3, 2006 | 02:42 PM
hukares's Avatar
For that size of terminal, there is a proper crimp tool and it is a little different than the smaller sizes. The crimp it makes is hexagonal. I always crimp and then solder when I do it. Your option if you can't solder or crimp is to buy the set screw type.
Old Mar 3, 2006 | 03:57 PM
cshamash's Avatar
I guess I will learn how to solder.It might be easier in the long run.
I tried the vice and the crimps and it didn't hold very well.
Old Mar 3, 2006 | 07:01 PM
jwa4378's Avatar
Yeah, that was more of an improvisional type thing. I did not have the proper tools, so I went MacGyver on it. And this vice was not a standard hand-held vice.....its was mounted to the work bench, and was about 8" long. Massively powerful.
I just did not want to wait, and it worked.
John
Old Mar 3, 2006 | 09:54 PM
cshamash's Avatar
Actually I ended up drilling a hole in the terminal and putting in a screw. Works ok.
Now I am putting in new speaker wire-God help me.
My hands are already raw and bloody and I still haven't got one in yet...
Old Mar 3, 2006 | 11:34 PM
SebringDemon's Avatar
hammer. use an anvil if you have one. dont hammer the entire crimp part flat, it will slide right now.
Old Mar 4, 2006 | 06:53 AM
jwa4378's Avatar
Use a hanger and some WD-40 (or KY) to lube it up, then PULL through the grommet, Dont push it, or you will be at it all day.
John
Old Mar 4, 2006 | 08:12 AM
hukares's Avatar
John
liquid soap works well too without the WD-40 smell.
