Wires under the carpet
It depends on where under the carpet, but I didn't use anything to hold my wires down. I cable tied them together every 10 inches or so and placed them on the side of the car under the carpet (on the side, not the floor). You can use tape to hold them down if you're worried about it, but I don't think they'll move under the carpet
The drivers side door sill will accomodate 0-gauge power cable and remote wires. This is in addition to the wires already occupying that space. The passenger side door sill will hold roughly two 0-gauge cable runs. The center tunnel is somewhat cramped, but the gist is that there is quite a bit of space for cable. If you run out of room, pull the seats and run it under the carpet
Right now my speaker wires and monster cables are run under the carpet and no tape is being used to secure it. I'll try using the door sill on the passenger side. That sounds easier than using the tunnel.
Originally posted by S2R
On the side? Is this by the door sill or the tunnel? Also, how did you keep the wires off the floor without using tape to hold it up?
nEVERCLEAR
Feb 14, 2002 07:09 AM
