wiring component speakers ?
Old May 24, 2009 | 04:02 PM
chamorru's Avatar
Default wiring component speakers ?
So I have a kenwood head unit w/ only 1 rca pre out. I want to run 2 amps, one powers my sub and the other powers my 2 component speakers in the doors.
Question is can I bypass the speaker wiring from the head unit and simply connect the components to the 2 channel amp (via speaker wire)and let my sub be powered by my other mono amp? Both amps are connected via RCA cables. The 2 channel amp has an RCA output so I run that to the mono amp.
In other words I don't really need to run a speaker wire from the head unit to the components if I'm running them off an amplifier because the amp is going to catch the signal via the RCA's...correct? I simply connect the components via speaker wire to the 2 channel amp and the crossovers do the rest?
Kind of a noob at installing car stereos I really just have a basic knowledge of it all. Any help is appreciated....
Old May 24, 2009 | 05:54 PM
DFWs2k's Avatar
what is the pre-out on your headunit labeled? what model HU are you running?
Old May 25, 2009 | 09:59 AM
chamorru's Avatar
its a kenwood kdc mp235. the pre out is a 2 volt rca pre out.
heres a link to kenwood site
http://www.kenwoodusa.com/Car_Entertainmen...nment/KDC-MP235
Old May 25, 2009 | 11:49 AM
imdarkrider's Avatar
invest in a new headunit, first off the 2v preout is horrible, get at least a 4v... also if you "Y" the amps you'll drop your voltage more right there
Old May 25, 2009 | 06:23 PM
2big4aS2000's Avatar
you can hook it up like you discribed.
Old May 25, 2009 | 07:51 PM
chamorru's Avatar
can you explain this statement further?
Old May 25, 2009 | 08:05 PM
chamorru's Avatar
i just read about 2volt vs 4 volt pre outs. when i had just the sub and the amp there weren't any noise issues at all. now that i will be running the componenets off an amp i guess this introduces more noise? therefore a 4 volt pre out(s) would help to decrease the noise?
Old May 25, 2009 | 08:07 PM
chamorru's Avatar
i realize the head unit isn't the greatest its about 2 yrs old actually but its pretty much what i have to work with right now..i may get a new head unit in a few months but not right now.
Old May 27, 2009 | 05:50 AM
chamorru's Avatar
so is anyone familiar with the advantages of 2volt vs 4volt pre outs? based on what i've read, it seems most new decks come w/ 2 or even 3 pre outs.
if thats the case then i can simply connect my 2 amps to the pre outs on the deck and forget having to run rcas from amp to amp, correct?
i'm assuming that with a deck that has 2-4volt pre outs (do they make any?) that my system will sound better?
Old May 28, 2009 | 05:59 AM
chamorru's Avatar
BUMP for confirmation of my research...c'mon wheres the audio experts at? maybe i need to go to an a/v forum lol.
