XM antenna in secret compartment
Old Apr 1, 2007 | 02:53 PM
HARDtoTOP's Avatar
Default XM antenna in secret compartment
I have heard ramblings about the XM antennas gettign signal from inside the secret compartment. I really don't see how this is possible since I thought it was line of sight. But, I am considering moving my antenna there if it does work. Has anyone tried this? Good or bad? I would just go out and try it myself, but I really don't feel like running the wire all the way in there just to see it doesn't work and then have to re-do it the way I have it now. Thanks
Jeff
Old Apr 1, 2007 | 03:14 PM
GrandMasterKhan's Avatar
the antennas can see through plastic which isnt terribly thick. Installing it inside the secrete compartment should work so long as the antenna is pointing up and that the compartment is made from plastic.
Obviously you would get better 'line of sight' if the antenna was on the outside of the car, but hey this is a convertible after all. Top down FTW.
Old Apr 1, 2007 | 03:23 PM
HARDtoTOP's Avatar
UPDATE:
I decided to go outside and try an idea I had to see if it could see through the trunk lid since it is thin sheetmetal.
I first tried sticking it inside one of the holes in the lid bracing, facing upward toward the lid. That didn't work too well, but it still got signal.
Then, I tried taping it to the inside of the outer metal on the trunk lid facing outward. Very bad.
Finaly, I stuck it directly to the inside of the trunk lid using the magnet, so the antenna is facing down. This seems to work great, and I am getting 100% signal 99% of the time. I haven;t taken it for a ride yet to see if it works reliably, but this might work and be totaly invisible.
I will update tomorrow when I test it out on the road. For reference I have the Terk mini antenna.
Old Apr 1, 2007 | 04:55 PM
PJK3's Avatar
i don't have XM personally - not yet at least. i keep toying w/ the idea tho. (for like 3 years now. )
but, i DO have the USGlobal BT 359 GPS antenna. i set it up in the SC, and it sees through the top of the secret compartment (and clothtop), and i can easily get 9-10 satellites w/o problems.
i'm not sure if they're the same spectrum, but it would seem close enough to the same idea... *shrug*
also, i know at least a couple guys here have done it w/ no issues. (including PAS2kNut iirc)
Old Apr 1, 2007 | 06:54 PM
Vapor's Avatar
Yes, it works. Mine has been in htere for a while now, no issues.
Old Apr 1, 2007 | 08:42 PM
NFRs2000NYC's Avatar
Originally Posted by sireousrex,Apr 1 2007, 06:23 PM
UPDATE:
Jeff...make sure your antenna is on the bracing, and not on the sheetmetal. If you have it on the sheetmetal, the magnet is powerful enough to suck metal particles in the air into your paint. Ask me how I know.
Old Apr 2, 2007 | 12:48 AM
Maskdman3's Avatar
On some vehicles I have seen the XM antenna installed under the dash up next to the windshield. XM usually works pretty well unless you park under an overpass or go into a parking garage.
Old Apr 2, 2007 | 03:20 AM
HARDtoTOP's Avatar
I will move it this morning.
Old Apr 2, 2007 | 04:51 PM
sTTook's Avatar
My Sirius antenna has been in the secret compartment for eight months now.
Old Apr 2, 2007 | 04:53 PM
HARDtoTOP's Avatar
The underside of the trunk did not work out well. I am going to have to try the secret compartment to satisfy my curiosity. More work
