xm ready?
Old Aug 28, 2005 | 12:00 AM
numairk's Avatar
Default xm ready?
I know the stock unit is xm-ready but what does that mean? can i cheaply install xm into it?
I do plan on changing the system eventually but at the moment money is a bit tight.
Old Aug 28, 2005 | 04:24 AM
jimmij's Avatar
Just buy the kit from Honda and you are ready to go. It is not cheap so shop around. If you are going to change it later, I would wait.
Old Aug 28, 2005 | 07:07 AM
s2ksimon's Avatar
if money is tight, then i suggest not going XM radio..
i believe its just the head unit that is all you have, so you'll need the XM receiver/tuner which plugs into the back of your head unit, and the xm antenna. Then the appropriate XM monthly package and away you go.
costly ? yes
but well worth an investment if you do spend a lot of your time driving in your car.
Old Aug 28, 2005 | 10:34 AM
steven975's Avatar
the factory XM costs way more than the following:
aftermarket head unit
modifry DCI for dash controls
XMDirect for xm radio
you'll get way better sound with aftermarket. You spend $500 on the factory XM and your sound still sucks.
Old Aug 28, 2005 | 10:05 PM
numairk's Avatar
thanks for the replies guys
i was thinking about buying this...
http://iweb.alpine-usa.com/pls/admn/item_i...gory=&p_main=10
the Alpine CDA9820XM
does the dci modrify work on this?
Old Aug 29, 2005 | 05:27 AM
jwa4378's Avatar
if it comes with an IR remote, yes, the Modifry DCI will work (I am 99% sure on this).
John
Old Aug 29, 2005 | 05:52 AM
S2000GT's Avatar
you could always buy something like the Terk commander (or similar xm unit) for around $125-150
Then youll need a PIE HON-AUX adapter (approx $80-100) which connect it to your OEM headunit - uses the cd changer port
So for $200-250 you can have xm directly connected.
I ran this setup for over a year with no probs and good sound quality.
Old Aug 29, 2005 | 03:15 PM
numairk's Avatar
thanks for the responses, i think ill wait till i can afford a headunit and some decent speakers.
-S2KING-
Feb 12, 2011 06:57 PM
getzy
Jan 8, 2009 10:02 AM
kev1025
Oct 29, 2005 06:03 AM
revhi
Jan 31, 2003 06:01 AM
