04 s2000, just orderd flashpro
Old Jan 31, 2010 | 06:48 PM
So-Lo's Avatar
Hopefully it works, but if not... It is a mistake on their part for telling me it would lol
Old Jan 31, 2010 | 07:12 PM
PsykotiK's Avatar
if not.. ill buy it from u for 400 lol
Old Jan 31, 2010 | 07:47 PM
Suzuka_Joe's Avatar
Originally Posted by So-Lo,Jan 31 2010, 07:34 PM
And i have also found a few websites where you can order flashpro for the s2000. And It says 04-08 usdm models with ecu code of pzx-a04 through pzx-a21. Mine is pzx-z05.
Check those last 3 digits on your Ecu again. It say A04-A21
Yours is Z05. Different ecu
It won't work
Old Feb 1, 2010 | 02:57 AM
spectacle's Avatar
Old Feb 1, 2010 | 06:31 AM
Gernby's Avatar
Former Sponsor
If there was a snowball's chance in Hell that the FlashPro did work on your '04, then I think that would provide a good upgrade path for AP1 owners. From what I recall, the AP2 V1 ECU will work with AP1's.
Godd luck!
Old Feb 1, 2010 | 09:22 AM
Hondata's Avatar
Former Sponsor
We have updated the web site to correctly reflect the part numbers as the FlashPro will not work on a non drive by wire S2000.
Here is the reason for the mistaken part numbers. The web site mistakenly listed the software versions supported not the part numbers. Software version PZX-A04 is not found in the ECU of part number PZX-A04 (an 04-05 S2000). Software version PZX-A04 is found in ECU part number PZX-A07 which is from an 06 S2000. Confused? We were.
Old Feb 1, 2010 | 12:13 PM
Suzuka_Joe's Avatar
Old Feb 1, 2010 | 09:50 PM
smirfs2k05's Avatar
I'll buy that flashpro off you
Old Feb 2, 2010 | 07:33 AM
DFWs2k's Avatar
lack of consumer research FTL
Old Feb 2, 2010 | 09:15 AM
devs2k's Avatar
You should get a refund if they told you it would work. To us, it's obvious it doesn't. But doesn't change the fact that whoever you spoke to gave you bad info.
