05 AP2 k-pro?
Old Apr 19, 2011 | 07:47 AM
Bigpeters2k's Avatar
Default 05 AP2 k-pro?
i tried to search for this topic but nothing popped up. but i was on Hondata website. and i see they made the K-pro for the 00-05 s2000, has anyone tired this or know anyone? and is it worth doing? just curious
Old Apr 19, 2011 | 06:23 PM
Andrie's Avatar
I just got mine. Don't have time to put it in yet. Will try next week and give you update.
Old Apr 19, 2011 | 07:46 PM
DFWs2k's Avatar
yes it is exactly the same as the earlier year models, what are you trying to find out
*edit* ok not exactly the same since yall already have an ap2 pcv valve
Old Apr 20, 2011 | 07:16 AM
if you would please looking forward to hearing about it.
Old Apr 20, 2011 | 07:24 AM
um i just wanted to know what are the gains/benefits of a K-Pro. never known anyone to have. everyone say the S is fast but faster after getting a chipped
Old Apr 20, 2011 | 08:15 AM
Spunkster's Avatar
Only the 2006 and newer vehicles have the newer valve cover. 00-05 have the earlier valve cover and if they use the K-Pro they must use the 06-09 valve cover ofr it to work.
Old Apr 20, 2011 | 05:15 PM
JUSTINTHECOASTIE's Avatar
Originally Posted by Spunkster
Originally Posted by Bigpeters2k' timestamp='1303313056' post='20487606
[quote name='DFWs2k' timestamp='1303271170' post='20486018']
[/quote]
ummm I thought with the 04-05 valve cover you can make it work
Old Apr 20, 2011 | 07:25 PM
DFWs2k's Avatar
Well if you want to start modifying valve covers, then you can use any of them.
If you want plug and play, use 06+.
The 04+ have the same pcv valve, so if you are an 04-05 going kpro, you would be more fiscally sound in not purchasing another pcv valve, just take out of your valve cover and transfer to 06+ valve cover.
Yes any tuning (done correctly by a pro) is good, and kpro is cool because you can keep obd port active.
Old May 16, 2011 | 07:11 PM
Andrie's Avatar
Just to follow up. I did the Kpro over the weekend. Some tips and what I found out.
1. The valve cover and sensors are a must.
2. All AP2 uses same PCV valve so you don't need to get them.
3. The cam pulse plate is reversed thread. The manual didn't say this and I couldn't see the marking since it is against the firewall
4. Take the oil pan off. Or it is a bitch to put on the chain cover with the pan on.
5. Honda monster torqued the crank pulley bolt!
Old Feb 5, 2013 | 05:01 AM
timg's Avatar
2. All AP2 uses same PCV valves so you don't need to get them.
All that to use kpro?
Yup. It's quite a bit of work. For people in non-emissions states, I would strongly recommend AEM. For those of us with emissions testing, the KPro is probably worth the initial headache.
Tim
