07 S2K Standalone Options
I have a standalone ECU for the dbw s2k using an AEM EMS and custom plug and play harness that I have had since 2006. The stock ecu stays in place to run the DBW and dash and the AEM EMS takes care of the tuning of the engine.
It would help because the system is complete plug and play and you need some form of Standalone EMS to run ITBs on this car. You would have to add a throttle cable for the ITB's. as the DBW system does not support ITBs
I think that the throttle cable from the drive by wire box may be an little short"not sure" as for idle control you can wire up a idle valve to the ITBs. or you can simply have the car idle a little higher to prevent stalling with the Itbs
Originally Posted by InductionPerformance,Feb 1 2011, 11:32 PM
We've been using AEM EMS on the S2000 DBW for a while. It works great. I would go with what fits your budget honestly.
Originally Posted by gernby,Feb 2 2011, 06:56 AM
What are you using the AEM EMS for that can't be done with a FlashPro? It seems that the only reason to use anything other than a FlashPro is if you want iVTEC, Nitrous, ITB's, or boost control.
thanks
