2002 tunning options
Old Oct 2, 2016 | 10:39 AM
C4vettrn's Avatar
Default 2002 tunning options
just got a 2002 and have some questions. I am new to these engines and have been reading as much as I can. I came from a 92 LT-1 corvette and the only tuning I am familiar with was doing data logging via Datamaster program on a laptop then sending file to a guy who would burn a new chip to plug into my EPU. I read the AP1 motors need a different or standalone system as opposed to the AP2. Do the AP1 computers use a chip like my 92 corvette that can be switched with a new program? I would really like to lower my VTEC without spending a small fortune on a stand alone system not to mention I am 50 and not as computer savvy as you younger guys. I guess what I am asking is what are my options? Thanks.
Old Oct 2, 2016 | 11:00 AM
snitm's Avatar
There is no "chip" to replace in the OEM ecu. It needs complete replacement.
Likely the most affordable solution would be Ballade's Doctronic ProECU-S2K.
Cheaper than AEM Infinity, just works with all the stock sensors.
Old Oct 2, 2016 | 11:39 AM
flanders's Avatar
If you don't want to go fully standalone a piggyback ecu is the best solution, look for a Greddy Emanage Ultimate or Apexi NEO cheaper.
If you're only looking to lower vtec and touching up the fuel these are more than enough.
Old Oct 4, 2016 | 04:32 AM
C4vettrn's Avatar
Copy, thanks.
Old Jan 2, 2017 | 03:38 PM
klapamos's Avatar
Hey all,
Im also looking for a new stand alone ECU for an AP1, but I need to pass emissions, suggestions?
Old Jan 2, 2017 | 09:36 PM
Singh_snisen's Avatar
Originally Posted by klapamos
hey all,
im also looking for a new stand alone ecu for an ap1, but i need to pass emissions, suggestions?
aem ems 2
Old Jan 3, 2017 | 03:09 AM
flanders's Avatar
No you wont pass emissions test with an AEM EMS.
You got Hondata Kpro which is the most proven so far but also most expensive.
Doctronics which is kind of a knock off kpro ecu, kind of unproven so far but seems like it could be a good choice.
MS3 from Reverant, really powerful and nice looking ecu which you can read more about a couple of topics down in this forum.
Old Jan 3, 2017 | 07:02 AM
in California I have passed emissions with this ecu no problem. Maybe ur state they look at it?
Old Jan 3, 2017 | 07:20 AM
flanders's Avatar
They don't perform an OBDII check in California?
Old Jan 3, 2017 | 07:25 AM
obd as in scan the motor for trouble codes? If so they do. But iv never had a prob with this as I don't have an evap canister neither an air pump. The ems2 can pretend to have these emission parts on
