2004 AP2 Hondata?
i am curious and was wondering if hondata has kpro or flashpro for the 2004 S2000? im planning on buying one but i want to know if they support the 2004. im sure they must be but after looking around its hard to know if they do or not. thanks!
I have no idea what a flashpro is, i read a little bit about it on their website but im the type of guy who dont know what things really are unless i get hands on and mess around a little. but Kpro is available for the 04 so ill be fine with that hopefully... any suggestions? should i buy an 04 and go kpro, or should i go for an 06 and get flashpro?
I was REALLY glad I had the DBW version when I found out about the FlashPro. You should spend some time reading about the pros and cons of the DBW AP2's, then read about the differences in features between the K-Pro and FlashPro. If you want to go with a serious build, then you may be better off with the '04-'05 and a K-Pro.
i had to do a little research on the DBW and ive decided to go for the 04-05 depending on which one comes my way first. as long as i can do Kpro and use a disk on a laptop and do some tuning etc.
Basically only for the DBW S2000's.
