2004 ap2 Kpro questions
Old Nov 17, 2009 | 04:51 PM
benlee02's Avatar
Default 2004 ap2 Kpro questions
I have a 2004 s2000 and wanted to find out if i needed to replace all the parts or some of the parts from the hondata list to get kpro
The following items must be replaced before the S2000 K-Pro can be used. These parts are not supplied by Hondata and should be purchased from a Honda dealer.
Crank sensor 37500-PZX-003
Crank wheel 13622-PCX-013
TDC sensor 37510-PZX-003
TDC wheel 14112-PCX-003
Valve cover 12310-PCX-020
Drain plug washer (for PCV valve) 94109-14000
PCV valve 17130-PCX-003
IAT sensor 37880-P05-A00 (not required, but stock IAT will read about 30 degrees hotter)
The approximate cost of these parts is $300-375.
Old Nov 18, 2009 | 02:42 AM
S2Timmy's Avatar
You have to replace all of the sensors listed. Install can be a PITA but is worth it IMO.
Old Nov 18, 2009 | 09:49 PM
benlee02's Avatar
anyone know where i can buy these parts?
Old Nov 18, 2009 | 11:11 PM
Mrfixit687's Avatar
At a Honda dealer.
Old Nov 19, 2009 | 12:17 AM
benlee02's Avatar
Originally Posted by Mrfixit687,Nov 19 2009, 12:11 AM
At a Honda dealer.
i did but they quoted me $543
Old Nov 19, 2009 | 05:55 AM
Hondata's Avatar
Former Sponsor
$317 including shipping
http://www.hondaautomotiveparts.com/
Old Nov 19, 2009 | 12:09 PM
RStoR's Avatar
Are the '06 sensors/parts compatible with the '04-05 OEM ECU? If a problem is encountered with the Kpro PRB ECU, can the OEM ECU be re-installed or do all sensors/parts have to be replaced too?
Old Nov 19, 2009 | 12:55 PM
Spunkster's Avatar
No they are not backwards compatible. IF you go back to the stock ECU you must swap the sensors and triggers back.
Old Dec 30, 2009 | 03:12 PM
Sobe_Death's Avatar
If you are looking to save some money...
The PCV valve is the same for all AP2 cars so if you are 04-05 you can reuse yours.
The IAT is from: ACCORD '88 - '93
CIVIC '88 - '95
CRX '88 - '91
DEL SOL '93 - '95
PRELUDE '88 - '01
These can probably be had for free to pennies.
Old Feb 15, 2011 | 09:46 PM
iMpOrTz_'s Avatar
im also in the market to get k-pro i have an 04 ap2
