aem ems
Old May 31, 2010 | 11:41 AM
Tobisenpai's Avatar
Default aem ems
I was just curious guys. I have an 05 honda s2000 and plan on going Forced induction soon and i need an aem ems. My question is that for an 05 could I use the same AEM EMS from someone with an earlier year s2000?
It would be much apprectiated for the help thank you
Old May 31, 2010 | 11:56 AM
Ian300D's Avatar
Yes you can. I recommend just getting the AEM Series 2 though as a lot of the first ones had little issue's here and there that you may not want to deal with. Plus if you ever need a older box serviced, it is not cheap.
Old May 31, 2010 | 12:14 PM
Tobisenpai's Avatar
OH thank you! thanks for the input i appreciated it!
Old May 31, 2010 | 12:20 PM
secondhandloser's Avatar
Yes. Also agree with going series 2
Old May 31, 2010 | 02:01 PM
Tobisenpai's Avatar
SO series to is a lot better? I thought i read on the forums that some people are still having a little bit of trouble on V2
Old Jun 4, 2010 | 07:00 AM
maluch's Avatar
The major disadvantages of series 1 are:
1. you need a laptop with a serial port or need to find a solution for connecting to the ems via a usb-to-serial converter, many such converters have trouble connecting
2. there is no knock signal filtering. if you have the car tuned at a tuner then this should not be a problem
3. series 1 has 512 kb internal memory while series 2 has a full 1MB.
all other differences are largely irrelevant for our motors. The 1MB is actually pretty useful since you can almost data log a full 30min on a high frequency sampling setting. I use series 1 and had to build a contraption to house my laptop so i can collect data while on the track. all the vibration is obviously not good for the hard drive.
Old Jun 4, 2010 | 07:48 AM
camuman's Avatar
if money is no issue, aem series 2. if money is an issue, aem 1052u series 1 box used. best bang for the buck.
Old Jun 4, 2010 | 07:52 AM
maluch's Avatar
i also forgot to mention that series 1 cant operate the new aem tuner software...
I dont have any experience with that software, but it doesn't seem all that ground breaking
Old Jun 4, 2010 | 08:16 AM
camuman's Avatar
i use aempro, its fine. its not like you cant tune a car on aempro series 1 box. you can make the car run well, make power, and be reliable. series 2 just gave couple new features that some may like.
Old Jun 4, 2010 | 08:17 AM
joes sled 2000's Avatar
I cant speak for the series 2 units , however when a series 1 box is setup properly it is awesome !
