AEM EMS V2
I haven't used a v2 ems, but the startup issue is very easy to fix. there are 2 resistors, one for the cam and one for the crank sensor. If the car is slow to start swap them out for a higher value resistor and the car will start up just like stock.
This is due to the very large variance of the cam/crank sensors that honda uses. some work perfect some dont.
i used 4.7k ohm resistors.
hmmm..intresting.
resistors....if i remember correctly. in guitar amplifires if you dont discharge the resistors properly one could die. if i;m thinking of the right part.
I'm guessing the same is true for a car's resistor?
or is that the caps?
anyways.
when changing the resistors do you have to solder it on?
or is it something you just switch out?
anyone else on this forum got some infos?
anyways.
