AEM Series 2 A/C problem
Old Aug 13, 2012 | 07:45 AM
Metcalfe's Avatar
Default AEM Series 2 A/C problem
Hello,
I seem to be having a problem with my AEM SERIES 2. I can't seem to get the car to run the A/C when at idle. The compressor will sometimes kick on for a few seconds but then switch back off. When the car gets moving the A/C starts to work and the compressor runs. When I come to a stop the A/C is still cold but I think that is just residual air and the compressor is still shutting off. Any Ideas?
I haven't messed with anything but the load compensation. Bumped that up to 7%.
Old Aug 15, 2012 | 05:42 AM
InductionPerformance's Avatar
Originally Posted by Metcalfe
Hello,
Triple check your a/c settings. Is the rpm high enough? If EVERYTHING checks out give AEM a shout. Maybe the wrong resistor(s) were used on the board.
UH-60DRIVER
Oct 25, 2015 02:01 PM
bois2k
Jan 6, 2013 07:44 PM
AWWHITE s2k
Nov 2, 2012 12:50 PM
AusS2000
Jan 26, 2008 05:58 AM
dut
Nov 23, 2004 11:52 PM
