Aem series 2 question
Does aem series 2 have a lean fail safe built into the system? I'm just wondering because mine would cut off when my afr spike lean. Still trying to figure if it's the aem doing it or my aem fail safe. But my failsafe isn't set to anything yet.
Yes the series 2 has lean fail safe (cut), if you have firmware 2v02 and have it enabled in the engine safety tab.
I found this on my software. Any idea what the settings should be? I see O2#1 kill and O2#2 kill. I can set them to on, but is there a way to set a specific A/F that it considers to be lean?
The Engine Protect Rev Limit is set at 0 RPM. I assume this means it will kill the engine to 0 RPM if it detects a lean state?
If it isn't there, you may have to setup the tab, options window, or individual options. Honestly I can't remember if I did that myself or if the last software update added it automatically.
I assume it has it's own parameters of what it considers lean.
Originally Posted by Habitforming' timestamp='1442977098' post='23755121
[quote name='rmerchant3' timestamp='1442882943' post='23753955']
[/quote]
There is a table called O2 Kill Limit where you set the O2 AFR cutoff based on engine load. Again, you may have to set that table up, I can't recall.
Do you have the information panel on the right side of the screen visible? It goes a long way toward explaining what all of the options do, although their descriptions could be improved in some cases.
Also, you can ignore the O2#2 stuff, as we only have 1 sensor.
