AEM speed sensor calibration
I have an AEM EMS V2 and i also have an aftermarket 4.56 diff waiting to be fitted. Do you need to use one of those yellow box things or is there a setting in the AEM EMS that will allow you to change the speedo calibration?
I imagine its not a question thats asked often but seems like one of those settings thats most likely hidden away somewhere.
Thanks
Thanks
Thanks
Thanks
I had to fit a speedo box so that i could calibrate it correctly. I think adjusting it in the EMS wont adjust what the speedo see's so you have to get done via a speedo adjuster. I think i got a plug and play one in the end.
