AEM V1 ITB base map needed!
Old Mar 15, 2012 | 03:29 PM
4forall's Avatar
Default AEM V1 ITB base map needed!
Like the title and description says. I am looking for a drivable basemap for AEM EMS v1 for an AP1.
If you need any more details to make/send one just pm me. Thanks.
Old Mar 16, 2012 | 09:45 AM
spectacle's Avatar
Get with Top Dead Center Performance down in Mobile: http://www.tdcperformance.net/ 251-661-6067
They'll be able to help
Old Mar 18, 2012 | 08:09 AM
4forall's Avatar
Thanks ill get a hold of them!
Old Mar 22, 2012 | 02:00 AM
chris_barry's Avatar
This link has a tuned program for an engine with the following build
https://docs.google.com/open?id=0Byx...RTFXWldQajIzQQ
F24C
Toda Spec C cams
Toda ITB's
ID1000 injectors
E85 fuel
50psi fuel pressure
The fuel and ignition maps are based on throttle position. The internal MAP sensor in the AEM is used for barometric compensation. You do not need the factory MAP sensor nor vacuum balancing chamber.
This will be close with standard injectors and pump fuel. Just trim the whole fuel table till it runs OK.
Happy VTECing.
DiegoB16
Mar 31, 2017 10:29 AM
DiegoB16
Mar 20, 2017 05:18 PM
indi00
Feb 27, 2015 06:59 AM
indi00
May 25, 2014 08:53 AM
S2BOOSTED
Jan 2, 2011 05:02 PM
