AP1 Kpro Parts
Old Jun 21, 2010 | 08:01 AM
s2000442's Avatar
Thumbs up AP1 Kpro Parts
I have a 2002 ap1 and will be installing a kpro. Anyone know of a store or online place to get the needs $300-$400 in parts? What parts are needed exactly?
I also heard the parts list includes a new honda valve cover also, is that correct? Why will the ap1 valve cover not work with a kpro installation? Do you also need to drop the oil pan also for this install?
Thanks
Old Jun 21, 2010 | 08:16 AM
vspc2nr's Avatar
http://www.hondaautomotiveparts.com
http://www.handa-accessories.com/index.html
2 places i get my stuff from, hardly at my local stealerships. GL
Old Jun 21, 2010 | 02:15 PM
DFWs2k's Avatar
Thanks
Mechanical modifications
The following items must be replaced before the S2000 K-Pro can be used. These parts are not supplied by Hondata and should be purchased from a Honda dealer.
Crank sensor 37500-PZX-003
Crank wheel 13622-PCX-013
TDC sensor 37510-PZX-003
TDC wheel 14112-PCX-003
Valve cover 12310-PCX-020
Drain plug washer (for PCV valve) 94109-14000
PCV valve 17130-PCX-003
IAT sensor 37880-P05-A00 (not required, but stock IAT will read about 30 degrees hotter)
The approximate cost of these parts is $300-375.
from here:
http://www.hondata.com/s2000kpro.html
Old Jun 26, 2010 | 12:47 PM
96-EJ6's Avatar
Thanks
Yes wou will need the new valve cover, the new cam sensor doesn't fit in the 00-05 cover. You will also need to pull the oil pan and the timing chain cover to install the new crank trigger wheel.
Old Jun 28, 2010 | 01:31 AM
jaundice's Avatar
majestic honda, ie hondaautomotiveparts.com is the best. They tend to have all of the parts in stock and ship quickly. Go ahead and get a new valvecover gasket kit too.
