Attack of the CEL light and OBD-II codes
Old Jan 7, 2011 | 02:43 PM
beretta37's Avatar
Default Attack of the CEL light and OBD-II codes
Yesterday my CEL came on and I went to autozone today and pulled the codes. This is what came up.
2002 S2000 76,916mi
P0301 - Cylinder 1 misfire
P0302 - Cylinder 1 misfire
P0303 -Cylinder 1 misfire
P0304 -Cylinder 1 misfire
P0300 - Random Cylinder Misfire
P1399 - Random Cylinder Misfire
Anyone seen this combo or know what direction I should head first?
Any help will be appreciated.
Old Jan 7, 2011 | 07:28 PM
HodnaS2000's Avatar
Same thing.happened to me yesterday. Car runs fine. I erased the.codes.to see.if they return but will be taking it to q shop fora.tune up and some work anyway. writing from my Droid. makes it.look like.damn morris code.
Old Jan 8, 2011 | 12:50 AM
EagleDon's Avatar
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
From other threads many have said they changed their injectors. I would not recommend this as it may set you back $400 and still have the CEL. 2 things: clean air filter and routing, then pull your plugs and see if they are discolored. I had these same codes pop up before and went to the NGK Iridium plugs. No issues after installing them. I also rotated the coils (4,3,2,1 to 1,2,3,4) and this seemed to work fine.
Old Jan 8, 2011 | 07:07 PM
beretta37's Avatar
Thanks for the advice. I will start with the plug replacement and air filter cleaning( I have a K&N) and report back.
Old Jan 9, 2011 | 01:20 PM
HodnaS2000's Avatar
I checked my plugs. Shitty Bosch plugs which were in it when I bought it were loose and the tip of the plug, not the electrode-the opposite side tip, had unscrewed itself from the plug. I guess it would be the cap. So far no codes have come back. I can't believe the plug itself was coming apart like that. Ngk or pulstar only is what I've always recommended. Stay away from Bosch.
SteelCoyote
Jul 17, 2015 11:04 AM
dhayner
May 2, 2014 06:17 AM
CtrlAlt
Aug 30, 2011 09:10 AM
JLEEzAP2
May 1, 2011 12:28 PM
macr88
Engine
Jan 21, 2010 10:40 AM
