Correction for speedometer inaccuracies
Old Aug 31, 2010 | 10:13 PM
DFWs2k's Avatar
Default Correction for speedometer inaccuracies
I have Kpro. When my speedo shows a steady 70 mph, a GPS states that I am only going 67-68.
What is the easiest way to fix this? I would be fine with it showing 68 in that situation, so I need to change something by 2.9411764%, according to my calculations, which could definitely be wrong.
Any help?
Thanks!
Old Aug 31, 2010 | 10:23 PM
DFWs2k's Avatar
For the map i'm running, my gear ratios are
1-3.266
2-2.130
3-1.517
4-1.212
5-0.972
6-0.780
F-4.764
I have an ap1 with stock tranny/diff, different wheels and tires than stock
Old Sep 1, 2010 | 06:00 AM
xredjar's Avatar
Don't know if this will help or not...but,
On my pretty worn stock tires, I'd show 1.5 - 2 mph slower on gps than indicated. When I got new tires (not stock tires, but same sizes), that changed to about .5 - 1 mph at 65 - 70mph.
Seems the speedos are pretty accurate from the factory, but tread depth can affect it more than I'd have thought.
Old Sep 1, 2010 | 06:23 AM
DFWs2k's Avatar
Yea, if that's the case, mine would still be off by around 2 mph at 70, which is why that's what I want to change it by
Thanks for chiming in!
Old Sep 1, 2010 | 06:50 AM
Gernby's Avatar
Former Sponsor
You need one of these.
http://www.ricks2k.com/products/yellowbox.php
Or I think Modifry makes one cheaper.
Old Sep 1, 2010 | 06:51 AM
Gernby's Avatar
Former Sponsor
However, you could also just bump up your tire sizes to get it right.
Old Sep 1, 2010 | 07:22 AM
DFWs2k's Avatar
I was thinking that the kpro could adjust what I need without the yellow box, maybe if I slightly change the final gear ratio? I just don't know how all that works
Old Sep 1, 2010 | 07:33 AM
Gernby's Avatar
Former Sponsor
I assume that you can probably adjust the speed that the K-Pro thinks you are going, just like you can with the FlashPro. However, according the Hondata, the instrument cluster displays it's own speed, and the ECU can't change it.
Old Sep 1, 2010 | 11:45 AM
DFWs2k's Avatar
ah ok, i came across something to that effect relating to rsxs when googling, sucks, hopefully next tires make it less inaccurate
Old Sep 2, 2010 | 09:06 PM
GrandMasterKhan's Avatar
255/40/17 will solve your speedo issue. This is the same tire size as offered OEM with the CR
