ECU Pins
Old Aug 30, 2011 | 04:16 PM
xredjar's Avatar
Default ECU Pins
Anyone know where to buy ECU pins for my 06 S2K?
I am trying to wire up my Innovate LC-1 Wideband, and need a pin to plug the output wire into the ECU.
Old Aug 30, 2011 | 05:13 PM
Topillogic's Avatar
Here you go
http://www.newark.com/tyco-electroni...11?Ntt=85C1211
Old Aug 30, 2011 | 05:29 PM
xredjar's Avatar
Thanks much!! Just got done placing my order.
Appreciate the help!!
Old Aug 30, 2011 | 05:59 PM
donaldmejr's Avatar
can a AEM be wired into the ECU also?
Old Aug 31, 2011 | 01:08 PM
xredjar's Avatar
I believe so....E15 is the pin # on the ECU.....and as long as the AEM has an output wire that has a range of 0 - 5.0 volts....should be good.
Old Aug 31, 2011 | 02:39 PM
donaldmejr's Avatar
pin E15 for the (ELD) better to use over pin E1 (2nd coolant temp sensor)
Old Aug 31, 2011 | 02:54 PM
xredjar's Avatar
Thanks Don....forgot to mention pin E15 is the ELD.
Old Aug 31, 2011 | 03:58 PM
donaldmejr's Avatar
sorry...that was a question. Which one would be better to use?
Old Aug 31, 2011 | 05:55 PM
xredjar's Avatar
Originally Posted by xredjar' timestamp='1314831253' post='20932701
[quote name='donaldmejr' timestamp='1314830378' post='20932662']
[/quote]
I'm going to use pin 15 the ELD. I don't know if one is better than the other, but I believe most use the ELD.
I used the link Topillogic provided and for 5 pins including shipping it was just over $7.
Old Aug 31, 2011 | 08:21 PM
donaldmejr's Avatar
Originally Posted by donaldmejr' timestamp='1314835117' post='20932885
[quote name='xredjar' timestamp='1314831253' post='20932701']
[/quote]
[/quote]
That's odd I only paid 2.80 for 20 pins with free shipping.
