Emanage Ultimate
Old Aug 16, 2010 | 09:21 AM
SRap1's Avatar
Default Emanage Ultimate
I may be buying a Emanage ultimate to tune my comptech kit, with 550cc Rc's and 10psi...
Will i need the greddy (boost) pressure sensor?
What is it used for?
Old Aug 16, 2010 | 11:22 AM
Gernby's Avatar
Former Sponsor
I believe the stock MAP sensor is fine up to 10 PSI, so you should only need an aftermarket sensor if you plan to go above 10 PSI.
Old Aug 17, 2010 | 01:30 AM
SRap1's Avatar
thats what i sorta got out of the research i did on the forums, just wanted to make sure.
Old Aug 17, 2010 | 05:15 AM
scareyourpassenger's Avatar
I would think that you would want bigger injectors to run 10psi.
Old Aug 17, 2010 | 11:33 AM
DBXFX's Avatar
yea i think the stock can handle up to 10-11 psi.
on a side note, the gm pressure sensor can be used with the greddy right? just plug and play?
Old Aug 20, 2010 | 02:45 PM
Kirpich's Avatar
Technically, yeah, they should interpolate properly. You know, 0V at idle (negative pressure), and 5V at 3bar, accordingly.
If you can, buy the greddy or a GM MAP. It's better to run ignition timing off of load, instead of RPM.
Hey, I was thinking, these digital Vac/Boost gauges that come with their pressure sending unit, they're 5V, aren't they? Maybe you can tap into it for greddy ultimate.?
s2konroids
Oct 4, 2010 07:01 AM
lvd1102
May 28, 2010 05:06 PM
NightStalker
Feb 7, 2006 02:42 AM
s2kboost
Aug 20, 2005 09:50 AM
Wesmaster
May 15, 2004 04:18 PM
