ems with wide band hook up
Old Nov 29, 2010 | 11:17 PM
Hershey's Avatar
Default ems with wide band hook up
Hi. i have a quick question that something i am confuse on. i am going to go with a aem ems series 2 and i already have a aem wide band uego. the blue = serial data logging right? does this mean i can put this into a pin and do data log run with my ems and come back and look at my afr like how the flash pro does for the civic si? i know my buddy with flash pro on the si can data log run on flash pro and come back and check out the afr to tune. so i am hoping aem is the same with there wide band uego. this will be on a 00 ap1 thanks for the help.
Old Dec 1, 2010 | 07:16 AM
maluch's Avatar
yes, you can log AFR's using aem ems. you need to connect to the UEGO to the ems, calibrate the ems, and data log. refer to the instruction manual for more info and come back with any specific questions
Old Dec 1, 2010 | 05:17 PM
Hershey's Avatar
thank you.
Old Dec 1, 2010 | 07:26 PM
InductionPerformance's Avatar
You have to wire the white wire (0 - 5v) to the O2 #1 input
Old Dec 5, 2010 | 09:07 AM
Hershey's Avatar
thanks man. i wanted to know this before i buy one and cant do this.
osidis
Nov 5, 2010 09:28 PM
JsRacingS2K
May 16, 2009 06:39 PM
Spec_Ops2087
Aug 26, 2007 09:41 PM
nicku
Dec 14, 2006 06:22 PM
