Engine stalling after Haltech install.
Old Jul 22, 2019 | 02:39 AM
S2GARAGENYC's Avatar
Default Engine stalling after Haltech install.
Hello all,
Recently put a haltech pro in my AP1, with either the basemap or my friend's tune (same mods), my engine will start and idle just fine. If I give the engine gas, and come off of it the rpms fall and it stalls out. I did the TPS calibration and it seems to be registering. My hunch is that it's MAP related, but not sure how to remedy it. That hunch could be totally wrong as well.
Old Jul 22, 2019 | 09:03 AM
aaronyuri's Avatar
Does it stall with the stock ECU? If not, then it isn't going to be a sensor issue.
Next step would be the idle config and whether or not idle control is engaging as the engine RPMs decrease. If it's not going into idle mode, then you need to find out why. If it's going into idle mode, then your idle config is off.
Old Jul 22, 2019 | 09:22 AM
The car runs like a top with the factory ECU. I just can't wrap my head around uploading my friend's exact tune file to my Haltech and having this problem
Old Jul 22, 2019 | 09:44 AM
aaronyuri's Avatar
No one car is equal. OEM ECUs come with various parameters and learning procedures to deal with the differences. Aftermarket ECUs not so much...
Old Jul 22, 2019 | 09:54 AM
I 100% agree with you here, but at the same time how are guys just tossing in these pre-tuned greddy emanage's?? Between AP1 and AP2 nonetheless!!
Old Jul 22, 2019 | 12:44 PM
flanders's Avatar
You are still using the factory ecu with the Greddy EMU, most changes done with that piggyback ecu will only affect full throttle.
Old Jul 22, 2019 | 01:44 PM
You know..I totally forgot that ECU is a piggy back lol. I'll see what I can do with the idle config and report back. As I'm revving up through the powerband the car does in fact sound good. So hopefully the idle business is all I have to worry about.
Old Jul 22, 2019 | 07:14 PM
EOE's Avatar
EOE
Can you log the start, rev and as it dies and share with us? I can take a look at the values and see if anything stands out.
Old Jul 24, 2019 | 02:58 AM
Yes definitely man, I appreciate that!
Old Jul 24, 2019 | 09:38 PM
bradyn's Avatar
Please post a video on YouTube and link here for all to see
