Flashpro Tune and Dyno
Make sure to replace the flywheel with something lighter while you're replacing the clutch. I just replaced mine with an 8 lbs Fidanza, and love it! It is still super easy to drive, but the it really brings the car alive!
Originally Posted by rydelow,Mar 1 2010, 01:18 PM
Any explanation of the big dip after 3k? If you look on my thread my tq curve is linear. Maybe vtec should be set higher because thats a big drop
Originally Posted by gernby,Mar 1 2010, 11:29 AM
The dip is normal, but occurs at different RPM ranges depending on the harmonics of the intake and exhaust (and everything between). Mine peaks at 3500 RPMs, then drops a bit. However, I was able to prevent some of that power drop by lowering VTEC to 3700 RPMs.
Originally Posted by crazysupratt,Mar 1 2010, 12:42 AM
opps my mistake
how many miles do you have on your car? stock clutch? i need to get a clutch myself. I'm only at 36k. what are you going with?
that doesn't mean you car won't like a lower vtec point. Your setup might want a vtec point closer to 3k rpm. Every setup will require a different vtec point and just because you have a stock airbox doesn't mean it wont want a lower vtec point. Only way of knowing is to tune the low cam upto 6k rpm, then do the high cam from 2700rpm and up and then make the vtec point where the two torque curves cross
Originally Posted by jdsaini,Mar 1 2010, 09:11 PM
The car has about 16500miles on it right now. It still has the stock clutch. I want to replace it with the toda high power clutch kit. I had a toda flywheel on my previous car (integra) and it was probably the one mod that i did that was most noticable.
I was only looking at how both calibrations with different vtec points still had the same dip at 3000 rpm thats all. So with an aftermarket intake it will change the tune and the hp/torque curves. That is what I love about the flash pro, I can continue to mod and adjust my tune to my current mods.
