Haltech ps1000
Old Jul 25, 2012 | 08:05 PM
manny-s2000's Avatar
Default Haltech ps1000
Hey guys I recently decided to go turbo from s/c and I opted to ditch the oem o2 sensor and use the aem wideband and new sensor instead. I am after help to wire it up, and in the process also wire up the Mac boost solenoid. The tuner can configure whatever is needed the main thing is to have them ready to keep the costs down.
Thanks guys,
Manny.
Old Jul 25, 2012 | 08:36 PM
FullBlown's Avatar
Former Sponsor
Manny, use any of the spare DPO outputs. The solenoid has two wires, it does not matter which side you supply 12volt to and a DPO output.
Old Jul 25, 2012 | 08:57 PM
Oh ok.. Well that sorts out the Mac solenoid then, any idea with the wideband?
Thanks LJ!
Old Jul 26, 2012 | 03:48 AM
b.r.i.a.n.'s Avatar
you need the auxiliary harness to wire up the wideband to the pro plug in ecu. as far as the boost solenoid, remember that the ecu comes in with a built in map sensor. it can read ~22 psi.
crisskro
Oct 9, 2013 07:46 AM
crisskro
Oct 7, 2013 01:24 AM
CJB22
Mar 16, 2013 07:38 AM
3ngin33r1
Jan 15, 2009 09:01 PM
Diddy
Aug 14, 2002 10:07 AM
