Haltech Wideband Install Question
Old Nov 21, 2016 | 04:18 AM
slowd16's Avatar
Default Haltech Wideband Install Question
How have people run the wires from the Wideband up to the Can Box? I de-pinned the connector to the wideband to bring it from inside the car to out but think it will still be too large to fit through the wire bundle behind the battery with the loom. Is there another spot that works? Should I make my own hole in the rubber grommet on that side?
Also, does the Power and ground wire on the second loom need to be hooked up when using the can cable to the Haltech? The directions seem to have confused me on that.
Old Nov 29, 2016 | 07:05 AM
Spartarus's Avatar
THIS.
The directions and video make no mention of the additional wiring, but the wiring diagram in the back of the directions show it wired.
...But there's power and ground on the 8-pin Haltech CAN loom...
I'll go post it on the Haltech forum and report back if I have any luck there. I already have it as a draft from when I was thinking about asking.
I'm interested in the answer too.
Old Nov 29, 2016 | 08:37 AM
slowd16's Avatar
Originally Posted by Spartarus
THIS.
Yeah, I'm leaning toward it being needed. I tweeked something in my back putting my engine in the car last week so haven't had a chance to mess with it.
Old Nov 30, 2016 | 02:22 PM
Spartarus's Avatar
Straight from Haltech:
"Yep, needs to be wired to power and ground. Doesn't have to be switched, should go straight to battery power."
Old Nov 30, 2016 | 07:37 PM
slowd16's Avatar
Good shit!!
Old Dec 12, 2016 | 08:31 AM
slowd16's Avatar
Just installed this yesterday. Did power right off the battery to the provided fuse, bolted it to the small control box by the battery. The wide band wire tucked nicely under the heat shield and along the firewall/trans.
liquidgsr
Dec 6, 2011 05:16 AM
siadam
Jul 3, 2010 08:59 AM
xtremesq
Mar 15, 2008 06:59 PM
pikkashoe
Nov 25, 2005 11:26 AM
TepEvan
Jun 14, 2004 01:49 PM
