Help with wiring solenoid on Aem Ems
Old Feb 2, 2010 | 08:17 AM
Suzuka_Joe's Avatar
Default Help with wiring solenoid on Aem Ems
I had my boost solenoid installed by the shop when i went for a tune and i didn't have the D plug with me for the aem ems to wire in boost control. They put the pin on the end of the wire and stuck it into the ems so it would work. it worked fine but they said i needed to add the connector when i got home so i wouldn't have any issues.
The plug has a white piece that goes into the middle through the plug. can someone explain how to secure the wire in the plug so it is hooked up right?
here's a bad picture of the plug. I put the wire into it in the right spot but i don't see how the white middle piece can lock in, it pushes and bends the wire down
Chiung
May 23, 2015 02:41 PM
Chiung
May 23, 2015 02:15 PM
Ek_Jak
Jun 1, 2011 05:30 PM
S2KSuzuka
Jun 26, 2007 09:02 AM
ideugene
Apr 17, 2006 07:40 PM
