Honda S2000 ap1 tuning on Hondata Kpro NO SENSOR CONVERSION!!! Plug and Play
Old Jun 7, 2017 | 06:19 PM
BalladeSports's Avatar
Former Sponsor
Default Honda S2000 ap1 tuning on Hondata Kpro NO SENSOR CONVERSION!!! Plug and Play
This is a Standard Hondata PRB Kpro typically used for 02-04 Acura RSX type S and now fitted for a 00-05 Honda S2000, drive by cable model. No need for cam, crank, valve cover conversion to 2006+ F22c S2k. We customized a jumper harness and added an ECT module for the water temp gauge. Everything works!!! AC, ECT, VTC if needed, Vtec of course, speedo, wideband compatible, and flexfuel.
Old Jun 7, 2017 | 07:19 PM
JUSTINTHECOASTIE's Avatar
What's the cost? Also, does this replace the other EMS you were r&d-ing?
Old Jun 7, 2017 | 09:47 PM
flanders's Avatar
Are you using the sensor converter from Doctronics?
Is it going to be approved by Hondata?
Old Jun 8, 2017 | 12:32 AM
dc2-2-ap1's Avatar
By chance is the ect module adjustable like the modifry unit? The 3 bar system on the Ap1 is too broad to be worth much. I really miss the 4 bar setup I had with the modifry on my aem v1. Will this utilize the obd2 port for CEL function and readability? If it has CEL function, is it the full oem spectrum or limited to certain functions?
Old Jun 8, 2017 | 05:31 AM
Modifry Products's Avatar
Former Sponsor
Sounds...unusual. KPro already operates the OEM temperature gauge, wonder why a separate module is needed?
Old Jun 8, 2017 | 08:06 AM
flanders's Avatar
The S2000 kpro ecu from Hondata has an additional board (part of the built in adapter harness) and I'm pretty sure it controls the OEM temp gauge.
Old Jun 8, 2017 | 08:36 AM
Janus00's Avatar
Holy crap I couldn't be happier about this news. I'm definitely interested.
Janus00's Avatar
Also interested in this.
Old Jun 8, 2017 | 10:52 AM
Former Sponsor
Yes the ECT module we used is from Modify. All the same functions.
Old Jun 8, 2017 | 10:54 AM
Former Sponsor
We did this to keep the Hondata Kpro standard and untouched essentially.
