Hondata Flashpro results and initial impressions
Old Nov 20, 2009 | 04:43 PM
06S2k07Si's Avatar
Originally Posted by ECale3,Nov 20 2009, 04:47 PM
What engine management where you running before?
Hondata reflash included with the KW high boost kit...sorry, I should have listed that.
Brian
Old Nov 20, 2009 | 04:46 PM
06S2k07Si's Avatar
ALL;
See the "Bearsek" post down at the bottom for the actual tune. The one listed above is not the correct one. Once I get the correct graphs I will re-list them...sorry.
https://www.s2ki.com/forums/index.ph...f=142&t=745479
Brian
Old Nov 20, 2009 | 05:07 PM
06S2k07Si's Avatar
[QUOTE=kitwetzler,Nov 20 2009, 03:48 PM] Is that a/f post cat?
Old Nov 20, 2009 | 09:46 PM
R1_Pilot's Avatar
Originally Posted by gernby,Nov 20 2009, 08:43 PM
What is "KW tune"?
Gernby,
sorry, I reread my post and its confusing.
The op posted the tune from the reflashed ECU that KW provides every customer through Hondata VS his own tune. What I was saying is that when KW worked with Hondata to get the reflash, they were basing it on a car with a cat and stock header. If you ad a J's header + a tp it will be leaner than intended by KW and Hondata.
I have a KW kit and I am using an ECU that was reflashed by Hondata with the tune for the SC. If I get a flashpro use it and then in a year decide to sell it, what happens to my ECU when I unlock the flashpro? ... most likely it will default to the Honda factory tune ??
J
Old Nov 21, 2009 | 03:50 AM
Gernby's Avatar
Former Sponsor
Oh. Hondata has said that the FlashPro will wipe out the original reflash, so your KW tune is gone.
Old Nov 21, 2009 | 06:42 PM
MasterForce's Avatar
hey but you can have different maps! like Valet and stuff
Old Nov 22, 2009 | 06:03 PM
EliteTuning's Avatar
nice and flat af curve. I wonder what your ignition timing is tuned to. If you can have king send u just the tq curves zoomed in so we can see the difference that would be great!
Old Nov 23, 2009 | 01:12 AM
CypherAZ's Avatar
Yeah but the flashpro comes with a supercharger basemap, i'm assuming thats the same as the KW reflash?
Old Nov 23, 2009 | 07:30 AM
R1_Pilot's Avatar
Cypher ... that does not help me ... once I unlock the Flashpro I will not have access to those maps anymore.
I just bought a spare ECU, now I have to get the keys/inmobilizer/ECU all reprogrammed.
J
Old Nov 24, 2009 | 08:13 AM
Bearsek's Avatar
Ask and you shall receive!
