Hondata Kpro4 is here! closed loop, bluetooth, live changes and more!
Old Jan 9, 2016 | 04:53 PM
  #21
Chitoki's Avatar
Originally Posted by surferboy120
Originally Posted by Chitoki' timestamp='1452371941' post='23847832
[quote name='surferboy120' timestamp='1452369227' post='23847799']
[quote name='rwheelz' timestamp='1424908662' post='23519387']
Wow need to send in ASAP. Worth it for live tuning alone! Will this affect our RSX-wideband-jumper-wire mod?
Get any info on the RSX-wideband-jumper-wire mod?
I made a post on the Hondata forums about this and they said the jumper mod is not supported and to use a stand alone wideband through one of the new inputs provided in kpro4
[/quote]
Do you know if one of the stand alones supports lean cut and all the good stuff an RSX O2 does? I am trying to figure out what I would loose going to Kpro 4. Thank you for the input.
[/quote]
Hondata said if you wire a wideband into Kpro4 like they dictate, you can use lean cut.
Old Jan 10, 2016 | 06:51 AM
  #22
surferboy120's Avatar
Originally Posted by surferboy120' timestamp='1452381070' post='23847917
[quote name='Chitoki' timestamp='1452371941' post='23847832']
[/quote]
[/quote]
[/quote]
Thank you for the input so it sounds like it may be a safer route to just use another standalone setup other than the RSX one at this point and get the benefits of KPro 4 especially with bluetooth and logging. Thanks again
Old Aug 14, 2016 | 11:43 AM
  #23
Ddubs_s2k's Avatar
has anyone had a problem with the readiness codes, I have kpro version 4.2.6 2003 s2000 , No check engine light but I failed because the system monitors where not supported such as Engine Misfire, Fuel system, Evap System, Secondary Air System. I have also tried clearing DTC and uploading the calibration but they still show not supported, I've done the emission drive cycle also. is there a way to set these readiness codes on the newer version? Do I need to try a Drive cycle with obd2 enabled ? Thanks for any help
Old Aug 14, 2016 | 02:12 PM
  #24
flanders's Avatar
Do you have emissions error checking and purge system enabled in your tune?
Old Aug 14, 2016 | 05:14 PM
  #25
Ddubs_s2k's Avatar
It might be disabled cause I had no cel then I enabled the obd and check engine came on , should I enable both obd and purge with the box selected upload and then drive cycle ?
Old Aug 14, 2016 | 10:01 PM
  #26
flanders's Avatar
Yes I would try that to start with.
I don't think you could get the readiness code without them, not 100% sure though
Old Aug 15, 2016 | 08:16 PM
  #27
Ddubs_s2k's Avatar
Thanks I appreciate it I will give that a shot !
Old Aug 18, 2016 | 02:21 PM
  #28
Ddubs_s2k's Avatar
So I have tried enabling the obd and purge was enabled , when I enable obd I throw a p0443 cel , I have tried the drive cycle and still shows Evap not supported, secondary air system not supported? do these systems ever even work on kpro ? My car is stock besides intake
Old Aug 19, 2016 | 12:15 AM
  #29
flanders's Avatar
I have both enabled and been running fine with not error codes.
Not sure if those systems are supported but if you got that error code you will most definitely not get a completed and passed drive cycle.
Mijae007
Sep 16, 2023 09:50 AM
nMeOnE
Jul 11, 2017 03:20 AM
picco97
Mar 31, 2016 04:29 PM
indi00
Feb 27, 2015 06:59 AM
indi00
May 25, 2014 08:53 AM
