how to wire up vafc 1
Ok first off i have a 2001 ap1 and a vafc 1 "but the clip on it is cut " . so i need to wire this up, cant use the frog harness or jumper harness .
Does anyone have a wire diagram to what wire is what on our car or what wire is to be put where .I realy need help on this .
i found the manuel from apexi ,but that dosnt realy help
or is there some place else i should be looking
thanks
thanks
This is the wiring for the VAFCII, the VAFCI is very similar except the orange wire is also a power wire, rather than VTC/TDC and will be tapped in as if it were the second red wire. It's been a while since I've done an AFCI but I think that's it...
AFC wiring
AFC wiring
