JDM s2000
Old Aug 21, 2013 | 10:10 AM
chad86's Avatar
Default JDM s2000
I am looking to get a JDM s200 that has been imported from Japan. Does anyone know if emanage ultimate will work with the JDM ECU? I know the emanage doesn't have the tuning power that others have but looking to find a cheap way to manage my budget turbo build
Old Aug 22, 2013 | 06:21 AM
chad86's Avatar
anyone?
chad86's Avatar
anyone?
Old Sep 4, 2013 | 03:23 AM
ikaros_s2K's Avatar
I was told that before i buy my car (jdm 1999 model) the previous owner had the e manage ultimate and it was working ok. Not a choice I would have made and specialy for you if you plan to turbocharge the s ..!
Old Sep 5, 2013 | 07:18 PM
s2k manic's Avatar
should work fine might call boom slang they build wiring harnesses could tell you if there is a difference. I ran an emanage for years they work great as long as you know the limits of the system which is basically injectors and timing in closed loop and control of vetc I would keep boost to 10 psi as the knock control doesn't work very well in the emanage as you will see when you data log with it good luck on your car
Ansat527
Nov 9, 2012 01:10 AM
TB
Feb 28, 2007 01:40 PM
S2KNJ
Aug 18, 2006 04:09 PM
